Whelp, I learned a thing or two this fine morning.
1). You people are all crazy, turns out I was doing everything right and my form has been perfect. Why y’all gotta be haters?
2). Redfish suck.
3). Weather men suck. And just so I am politically correct, Weather ladies do too
4). The tide ALSO sucks.
5). Un-identified large species of fish that blow up on your fly and immediately steal it before you know what happened - suck
5. The wind (see if you can guess it?) . . . Blows (got you, didnt I?)
So, now that we got that out of the way, I did learn a few interesting things for real:
1). I am far worse about releasing the line from my line hand than I realized. Worse, even when I remind myself not to let it go, I still let it go. Apparently my left hand has a mind of its own.
2). Keeping my butt by my forearm is as hard as it sounds even when flyrods are not involved, but you all are right that distance is greatly and positively impacted when such things happen - even if it is a rare occurance because you suck.
3). None of that was actually the problem causing the looping around the butt. (This just sounds dirty, glad we are on a fishing forum).
So, here’s what happened. I did everything right about 3 out of 10 times that i remembered. I paid really close attention because everything that happens when I cast is as big a surprise to me as it is for everyone else. 10 out of 10 times, the cursed looped butt thing happened.
Turns out, it is NOT happening on my last cast, it was happening on my first cast. I tried everything to make it stop, but it magically happened. Dark magic, but still magic.
But it turns out it isnt magic, it was an unexpected other cause that I only discovered because the tide was so low that I had to get out of the boat and wade. Which meant leaving my stripping bucket behind.
Out of about 20 or 30 casts on foot - sans stripping bucket, not one single time did I get the butt loop phenomenon.
Then it occurred to me that all of this started when I started using the stripping bucket. Something about the angle of the line coming out of the bucket on the first cast is causing it.
