Should I be worried? - Trim Tab Anode
A month ago I put a Jack Foreman prop on my Suzuki 60, which required me to shave down my trim tab anode a bit. A few trips ago I felt a thump while on plane and once I got back to the ramp I noticed that the anode was gone, leaving a sheared off stainless steel bolt.
I have run the skiff a few times after this and definitely feel some torque steer, but my main concern is corrosion.
I have tried to remove the sheared bolt by drilling a pilot hole and using a screw extractor but I think the SS bolt is too hard for this to work. My next step would be finding a welder to tack weld something onto the sheared bolt to gain some leverage and eventually extract the bolt so I can put a new anode in.
Should I be concerned about corrosion over time and eventually get to it, say, “f it” and roll with it as is or should I be calling a welder ASAP?
Moved to this forum for more exposure and future reference.
If you decide to do something, do it now rather than later. The bolt could get fused in there in time and you’ll never get it out. FWIW , I ditched the trim anode on my old Tohatsu 60 and had to really cut the one on my Tohatsu 30 way down.
Yea. Its odd that you put a prop on that big. Photos would help alot here
Very common with a Foreman prop.
Foreman props are made to run high on a jack plate and partially out of the water, so they are larger and have much more cup than standard props. I’ve ran them for over 16 years across three boats - never had to get one rebuilt and I run across a lot of sand.
The corrosion is one thing, but the tab is at an angle for a reason - to offset prop rotation and help balance the engine.
This may be something for Professor @Smackdaddy53 to give advice on.
Once you get the bolt out replace it and get another anode. If it’s a tiller you need either the anode set correctly to counter prop torque or cut it flush and get a good compression plate and it will help counter the prop torque when running the jackplate lower.
What Smack said, and to add a bit more. If TQ steer is still an issue, Bobs TQ tamer helps mitigate it as well. Problem I have is my tab isn’t in the water, so it doesn’t do much. I put the tamer on, and it didn’t completely eliminate the TQ steer, but did lessen it.
Okay thanks everyone for the advice. I guess I’ll find some time off the water and get a welder or something to help me get this dang bolt out, then put a new tab in once I trim it down. I’ll manage the torque in the meantime and keep an eye on corrosion.
Until you replace the large trim anode, replace any other anodes on the Suk to help compensate for the largest anode on any outboard.
