Coosa board application
Glad to see this site up and running so quickly, pretty amazing. I recently purchased a 1976 elite hull to refurbish, someone gave me 2 sheets of 1/2" coosa board with red markings, never used the stuff. All my experience is with okoume or meranti, can some one school me on its use. I’ve made a console so far that seems strong enough but was going to add a front casting deck, stuff doesn’t seem to be very structurally sound. maybe this is not the right product for a deck, wondering how wide a span I can do, I’ll be using epoxy and glassing both sides, any info appreciated.
It’s generally used in Transoms or areas where screw retention is desired, such as trolling motor mounting. In these cases the deck will be primarily a Divinny or similar foam, with a section of coosa, where the TM would mount.
It’s rarely used for whole decks or soles due to its weight.
Welcome aboard @arace Glad to have you join us.
Coosa along with various other “foam” type cores help create the structure along with resin type and fiber loading. In many “wood” builds the wood provides the structure and resin/fiber seal the wood.
For a console, a single layer/maybe 2 of 1.5oz csm would likely suffice over say 15lb coosa, but for a casting deck one may require a layer or two of 12oz biaxial or 17oz biaxial or even some added support stringers on the bottom side depending on span and load.
thank you @zika, under my avatar my name was andy race on the MS forum, need to create a new one, also thanks for info @jcdesigns and @mikecockman
What JC wrote. When you add a skin of glass your coosa will stiffen right up. Hmm… that sounds a little wrong.
Seriously, if you have enough 1/2 “, you can double it up. Twice the thickness = 4X stiffness. More or less.
