I have a 21’ Stiffy Guide that I snapped in the mud. I used their insert kit to repair it, but it’s down to 20’ 2". I wish it was a lot longer.
I came across a 3’ section of the tubing and I’d like to add that to the pole. My concern is the extra weight of two additional inserts making the pole heavy.
I can buy a new point and cut it at the old point. If I stick the new point into one end of the 3’ tube and use the repair insert on the other, I can get away with just one additional insert piece and still get 23’.
Before I order the pieces, how much heavier do you guys think those two 12" inserts will make the pole. I’d like to avoid the expense of a new 23’-24’ pole.
When I assembled my MHX pole, the tubes and ferrules were light. The fork and tip were a larger percentage of weight than I imagined they would be. I’m guessing the is intentional so the ends aren’t as buoyant.
