For Sale: 2001 Hells Bay Waterman 18: 23 Hours on the Tohatsu! SOLD
OVERVIEW
A “no-frills” hard-core sight fishing machine. Focused purely on performance, the Waterman is a top performing skiff reduced to the essence of what it takes to fish at the highest level. A great boat for everything from the bayous of Louisiana to the mangrove creeks of the Everglades National Park, the Waterman is a refined fishing tool. Chris Morejohn calls the Waterman “the ultimate shallow water fishing skiff for cost”.
  • 2nd Owner, “Barn Find” (selling for a friend who is no longer able to use the boat due to health issues and advanced age; skiff has been sitting undercover in his back yard for the last 3+ years)
  • Hull Number 406
  • 18’ length, 73” beam
  • Guide Green hull with light beige non-skid
  • Light weight, tiller model, no floor with cooler step, drafts about 4”
  • EZ Loader Trailer
  • Heavy Duty rubrail
  • New Maxxis tires
  • New starting battery
  • Electric Winch
  • 22’ Biscayne Rods Push Pole
  • Custom cover
ENGINE
  • 2014 Tohatsu 50 HP 4 stroke short shaft, mostly likely less than 100 hours
  • Fresh water flushed after use
  • Full-Service August 26: thermostat, impeller, fuel filter, oil filter, spark plugs, engine oil, gear oil, pump case liner, pump case gasket, guide plate, impeller, etc.
  • Compression in each cylinder at or above 200 psi
  • 3 blade stainless steel prop (with extra 4 blade prop)
COCKPIT
  • Tiller model with “coffin box”. Owner does have the “bridge” that can be installed between the port side- and starboard side compartments
  • Comes with a side console that came with the skiff from Hells Bay when manufactured should a new owner wish to convert from the tiller
  • Port side compartments are divided: plumbed live well in front, dry storage in back
  • Moonlite Marine spring hatch holders all in good working condition
  • Starboard side compartment houses the starting battery, battery switch, fuse panel, etc.
  • Front compartment houses the fuel tank (22 gallons) and trolling motor battery (will need a new one), deep gutters with great dry storage
  • Port- and starboard side rod holders with under gunnel SeaDek with rod storage up to 9’ rods
  • Bow toe rails
  • Front casting deck
  • Poling platform with removeable sissy bar
  • Stiffy push pole holders, push pole caddy on poling platform
WHAT’S NEEDED
  • The fuel tank will be drained, but recommend that it be professionally cleaned before use
  • Suggest all fuel lines from the tank to the motor be replaced
  • The non-skid is in “good” condition, but could stand to be redone (especially inside the coffin box where there is some peeling)
  • There are minor spider cracks in a few spots (at front bulkhead, inside the cockpit and in the bilge area)
  • The under gunnels SeaDek looks fine, but may be degraded
  • The hull is in pristine condition, no oyster rash or other damage, shines bright as new. Suggest it be thoroughly cleaned and re-waxed
  • Trailer needs some hardware (safety chains are rusty, could use a new jack, etc.)
OTHER DETAILS
  • Offered at $36,000
  • Boat is in South Florida and can be seen on appointment; transportation for buyer can be arranged
  • Please DM with any questions
Thanks for looking!
Definitely newer than a 2001 motor.
Lots of potential. Love that sticker on the front of the coffee box. GLWS to your buddy! Shouldn’t last long.
Good catch, thank you. It is a 2014 (according to the serial number 047371AD).
Charlie has some cool stories that go along with it too:)
Really nice set up.
Thanks. It’s a sweet skiff for sure. Find me a buyer!!
That’s a nice sled
Thank you! Find us a buyer!
Nice job on the clean up Dave! GLWS👍
Maybe @VinnyL wants to get one turn-key🤣
If Jack calls , I sent him
Thanks, appreciate it!
Scan just completed. 23 hours on the Tohatsu!
The Tohatsu has 23 hours on it! Clean as a whistle.
Cheers to Tim, the new owner!
Tim got a gem. Is he a member on SkiffHQ?
He will be! Gave him a sticker and showed him the forum on his phone!
