I will charge exact shipping. Should be $4-5 via USPS Ground Advantage. Call or text for photos/questions. 253-736-5456
406 Trout Vintage Series. DT4F. Brand new in box. $65.
406 Trout Vintage Series. DT5F. Brand new in box. $65.
Airflo Euro Nymph. 0.6mm. 82.5’. The line has been used, but has plenty of life to live. There is a homemade loop on the tag end and a factory loop on the head. $35.
Airflo Euro Nymph. 0.6mm. 82.5’. New in box. $45.
Airflo All-Round Performance Super Dri Elite Trout. DT5F. Excellent condition. $40.
Airflo Bass Muskie Super Dri Big Flies & Poppers. WF9F. New in box. $85.
Aiflo Ridge 2.0 Bandit. WF5F. This was spooled on a reel and possibly fished once. It is in excellent condition and comes with a leader. $50.
Airflo Ridge. 2.0 Tactical Taper. WF4F. New. $50.
Airflo Ridge 2.0 Superflo Power Taper. Fished once in excellent condition. Factory loops on both ends. $50.
Airflo Ridge 2.0 Universal Taper. WF5F. This was spooled on a reel, but hasn’t been fished. There are some light backing stains. $50.
Airflo Super Dri Cold Salt. WF8 Sink 7. New in box. Retails for $90. $70.
Airflo Superflo Power Taper. WF4F. Excellent shape. Factory Loops. $50.
Airflo Superflo Power Taper. WF4F. New in box. Retails for $100. $80.
Airflo Superflo Power Taper. WF8F. New in box. Retails for $100. $80.
Airflo Superflo Streamer Max. WF5F. New in box. Retails for $130. $100.
Airflo Superflo Streamer Max. WF6F. New in box. Retails for $130. $100.
Airflo Superflo Streamer Max Long. WF6/7. 200 Grain. New in box. Retails for $130. $100.
Airflo Superflo Streamer Max. WF8F. New in box. Retails for $130. $100.
Airflo Superflo Tactical Taper. WF3F. New in box. Retails for $100. $80.
Airflo Superflo Tactical Taper. WF4F. New in box. Retails for $100. $80.
Airflo Superflo Universal Taper. WF4F. New in box. Retails for $100. $80.
Airflo Xceed Trout. WF9F. New on spool, but no box. $60.
Cortland 444. Intermediate Rocket Taper. Clear Camo. WF7I Type 1. This was spooled on a reel, but I am not sure if it has been fished. The line appears to be in great shape. There is a no loop on the head and a nylon loop on the tag end. This comes with the packaging and original CD. The CD has not been tested. $50.
Cortland 444. ST7S Shooter. I don’t know a whole lot about this line. It looks like a floating line that has a loop connecting a sinking portion. The loop connection between the 2 could be better. $10.
Cortland Euro Nymph Braid Core .022. New in box. $45.
Cortland Fairplay. WF7S. I am not sure if this has been used, but line is dusty/dirty from storage. Should work in a pinch. $10.
Cortland Indicator Trout Series. WF4F. New in box. $80
Cortland WF6F. This line has been used, but has life to live. It could use a wipe down or just fish as it is. Nylon/braided loop on head. No loop on tag end. $20.
Cortland WF5F. I think this is a modern trout line, but not 100% certain. The line is used, but in great shape. No loops on either end. $35.
Cortland Precision Compact Switch. New in case. Retails for $90. $70.
Cortland Streamer Sink Tip 25. WF8/9 300gr. New in box. Retails for $100. $80.
Cortland Tarpon. WF7F. Lightly fished and in excellent shape. Factory loops on each end. $70.
Cortland Trout Boss. DT3F. New in box. Retails for $100. $80.
Cortland Trout Boss. DT4F. New in box. Retails for $100. $80.
Cortland Trout Boss. DT5F. New in box. Retails for $100. $80.
Cortland Trout Boss. DT6F. New in box. Retails for $100. $80.
Cortland Trout Boss. WF5F. New in box. $70.
Cortland Trout Boss. WF7F. New in box. $70.
Cortland Trout Boss. WF8F. New in box. $70.
Cortland 444 Peach. WF3F. The line was spooled on a reel, but hasn’t been fished. Factory loop on head with a leader, no loop on tag end. $50.
Cortland 444 Tropic Plus. WF10F. The line is used, but appears to be in good shape. No loops. $40.
Cortland Tropic Plus. WF11F. The line is used, but appears to be in good shape. No loops. Has some black sharpie marks on the line. $40.
Mystery Floater. WF5F or WF6F. Came off an Orvis Battenkill Disc 5/6. The head has a braided loop. Line is lightly used and in good shape. Looks like an Orvis floating line. $20.
Mystery Floater. WF5F or WF6F. Probably Cortland or SA. This came off a Tibor Tail Water. The line is in great shape with factory loops on both ends. Total line weight is 23 grams. $25.
Mystery Floater. WF5F or WF6F. Probably Cortland brand. $25.
Mystery Floater. WF5F or WF6F. Probably Cortland brand. Factory loop on head and homemade loop on tag end. $25.
Mystery Floater. WF8F? There is a factory loop on the head, but beneath loop it has split. You could fish as is, but may not be a bad idea to cut it off. No loop on tag end. This came off an Orvis Battenkill Mid Arbor IV. $20.
Mystery Floater. WF8F. This is a saltwater line that came off a Tibor Everglades. The line is in great shape. No loops. Leader on the head. $25.
Mystery Floater. WF10F? This came off a Ross Cimarron II 9/10. The line has little use and has a factory loop on the head. About 15’ from the tag the line was spliced together. You could honestly just cut this last bit off, but I left it as is. Chances are slim you are casting a 10wt 90’ anyways. $15.
Mystery floater with slime line attached. This is a bit of an unknown to me. This came off of a Tibor Riptide. Appears to be in decent shape. No loops. $10.
Mystery Floater with intermediate tip. I believe this is a WF5F/I. The line is in excellent shape with factory loops on each end. $50.
Mystery Full Sink 6wt. Line is in good shape. There is a mono loop on the head and a homemade loop on the tag end. $25.
Mystery Saltwater Floating line. I believe it is a WF8F. No loop on head. Homemade loop on tag end. Line is in good shape. $25.
Rio Avid Trout Gold. WF6F. New in box. $60.
Rio Saltwater. WF9F. The line has been used, but has life to live. Homemade loops on each end. $20.
Mystery Saltwater Line. I was told it is a Rio Outbound 10 or 11wt line. I can’t positively identify this. Line looks to be in good shape. $25.
Mystery Slime Line (8wt Bonefish). Used but in great shape. $35.
Mystery Saltwater Floater. This is a WF13F or WF14F. Line has been used, but is in good shape with lots of life to live. $20.
Northern Sport Aquanova. WF6F. This line is new on the spool. Unfortunately, the line dusty from storage. This would benefit from being wiped down. $15.
OPST Pure Skagit Commando. 225gr. Used but in great shape. $45.
Orvis Clearwater. WF6F. This was spooled on a reel, but never fished. This has a factory loop on the head with a trout leader attached. $35.
Orvis Hydros HD Ignitor. WF10F. The line has very little use and is in great shape. The tag end loop shows a little wear. $50.
Orvis Pro Power Taper Smooth. WF6F (I think). Spooled and fished once. Factory loops on each end. $70
Orvis Wonderline Trout. WF8F. This line isn’t the prettiest, but should be good for lawn casting or as a back up outfit. The line would definitely benefit from a wipe down. $20.
Orvis Wonderline Trout. WF6F. This was spooled on a reel, but has never been fished. There is a mono loop on the head and no loop on the tag end. $35.
Rede River TW B-Line. WF6F. This is in excellent shape and has been fished twice. Braided loops on both ends. $30.
Rio Clouser Coldwater. WF6F. This was spooled on a reel, but hasn’t been fished. There are factory loops on each end and a leader on the head. This comes with the box. $50.
Rio Coldwater Series InTouch Striper WF10F. Lightly used and in excellent shape. $60.
Rio Creek. WF3F. Excellent condition with factory loops. $75.
Rio DirectCore Flats Pro. WF9F/I. New in box. Box is a little beat up. $100.
Rio Elite Gold. WF4F. This was spooled on a reel but hasn’t been fished. Factory loops on both ends and leader on the head. Retails for $130. $95.
Rio Elite Grand. WF7F. New in box. Retails for $130. $100.
Rio Elite Perception. WF3F. Comes with the box and is in excellent condition. This was spooled, but not sure it is was ever fished. $70.
Rio Elite Perception. WF5F. Spooled, but appears unfished. Comes with the box and spool. $70.
Rio Elite Predator. WF10F. Spooled, but appears unfished. $70.
Rio Elite Tropical Outbound Short WF9F. The line was spooled on a reel but has never been fished. $110.
Rio FIPS Euro Nymph #2-5. New with box. Little fuzzies on head loop. $45.
Rio FIPS Euro Nymph #2-5. New with box. $50.
Rio Elite Tarpon. WF12F. New in the box. $110..
Rio Flats Pro. WF6F. Spooled, but can’t remember if it was ever fished. Looks excellent. Factory loop on tag end. Leader on head. $90.
Rio Gold Premier. WF5F. New in box. $80..
Rio Grand. WF4F. This line has seen quite a bit of use. It is dirty/stained and could use a wipe down. I probably wouldn’t use this for anything other than lawn casting. $10.
Rio Intouch Gold. WF4F. New in box. Box is a little tattered. Retails for $100. $80.
Rio Intouch Gold. WF7F. New in box. Retails for $100. $80.
Rio Intouch Outbound Short. WF5F/I. New in box. Retails for $100. $80.
Rio Intouch Outbound Short. WF7F. New in box. Retails for $100. $80.
Rio Intouch Outbound Short. WF7F/I. New in box. Retails for $100. $80.
Rio Intouch Perception. WF4F. New in box. Retails for $100. $80.
Rio Intouch Perception. WF7F. New in box. Retails for $100. $80.
Rio Intouch Trout LT. WF3F. The line has been fished, but is in great shape. Factory loop on tag end, no loop on head. $60.
Rio Lightline DT1F. This was spooled on a reel, but has never been fished. $80.
Rio Outbound Short. WF7I. New in box. Retails for $100. $80.
Rio Outbound Intermediate. 8wt. Used, but in great shape. Factory loop on head. No loop on tag end. The clear portion is a little tacky to the touch. $45.
Rio Outbound Intermediate. 10wt. Used, but in great shape. Factory loop on head. No loop on tag end. $50.
Rio Perception. WF3F. The line is in excellent shape and has only been fished a few times. There are factory loops on each end. $60.
Rio Elite Technical Trout. WF3F. New in box. Retails for $130. $100.
Rio Premier Bank Robber. WF5F. New in box. Retails for $100. $80.
Rio Premier Bank Robber. WF6F. New in box. Retails for $100. $80.
Rio Premier Creek. WF3F. New in box. $80..
Rio Premier Gold. WF5F. Spooled, but never cast. $80.
Rio Premier Lightline. WF3F. New in box. $80..
Rio Premier Outbound Short. WF6I. New in box. Retails for $100. $80.
Rio Premier Outbound Short. WF6I/S3/S5. New in box. Retails for $100. $80.
Rio Premier Outbound Short. WF6F/H/I. New in box. Retails for $100. $80.
Rio Premier Outbound Short. WF7F. New in box. Retails for $100. $80
Rio Premier Outbound Short. WF7F/H/I. New in box. Retails for $100. $80
Rio Premier Outbound Short. WF7I. New in box. Retails for $100. $80.
Rio Premier Outbound Short. WF7I/S3/S5. New in box. Retails for $100. $80.
Rio Premier Outbound Short. WF7I/S5/S7. New in box. Retails for $100. $80.
Rio Premier Outbound Short. WF8I/S5/S7. New in box. Retails for $100. $80.
Rio Premier Striper. 400gr. New in the box. $80..
Rio Premier Technical Trout. DT3F. New in box. Retails for $100. $80.
Rio Premier Technical Trout. WF4F. New in box. Retails for $100. $80.
Rio Premier Technical Trout. DT4F. New in box. Retails for $100. $80.
Rio Premier Technical Trout. DT5F. New in box. Retails for $100. $80.
Rio Premier Technical Trout. WF4F. Used, but in good shape. Some backing stains. $50.
Rio Saltwater. WF11F. The line is used, but is in solid shape. No loops. $40.
Rio Sinking line. 6wt (full sink). This has been used, but in solid shape with life to live. Homemade loop on head. No loop on tag end. $20.
Rio Streamertip DC 400gr. New in box. Comparable line from Rio retails for $100. $50.
Rio Tropical Outbound Short. WF9F. Spooled, but never used. Light backing stains. $80.
Rio Winter Redfish WF9F. This was spooled on a reel, but has never been fished. $80.
Scientific Anglers Amplitude Smooth Creek Trout. WF3F. Lawn cast or fished once. Line is on a mismatched spool. $60.
Scientific Anglers Amplitude Smooth Trout. WF2F. New, no box. $80.
Scientific Anglers Amplitude Smooth Trout. WF3F. Excellent shape, some stains from backing. $70.
Scientific Anglers Amplitude Smooth Trout. WF6F. Spooled on a reel. Never cast, fished, etc. $80.
Scientific Anglers Amplitude. DT4F. New in box. Retails for $130. $100.
Scientific Anglers Amplitude MPX. WF7F. New in box. Retails for $130. $100.
Scientific Anglers Amplitude MPX. WF8F. New in box. Retails for $130. $100.
Scientific Anglers Amplitude Textured. DT4F. New in box. Retails for $130. $100.
Scientific Anglers Amplitude Textured. DT5F. New in box. Retails for $130. $100.
Scientific Anglers Amplitude Textured Infinity. WF5F. Excellent condition, possibly unfished. $100.
Scientific Anglers Amplitude Tropical Titan. WF10F. New in the box. $100.
Scientific Anglers Amplitude Trout Standard. WF3F. Fished once or twice and in excellent condition. Factory loops on both ends and has a leader on it. $75.
Scientific Anglers Mastery Infinity. WF5F. Looks new. $70.
Scientific Anglers Mastery Textured Series Streamer Express. WF300S. New in box. $50.
Scientific Anglers Mastery Trout. DT2F. Spooled, but never fished. $65.
Scientific Anglers Mastery Trout. DT3F. Lightly fished. No loops. $50.
Scientific Anglers Mastery Trout. WF6F. Lightly used and in good shape. There is a nick at base of the head loop, so probably best to cut it off. $50.
Scientific Anglers Mastery Series. Spey Classic. WF6F. NIB. $65.
Scientific Anglers Mastery Series. Spey Classic. WF10F. Demo line in great shape. $50.
Scientific Anglers Mastery Series. Spey/Salmon. WF12/13F. NIB. $60.
Scientific Anglers Mastery Series. Spey Shorthead Multi Tip. 4 interchangeable tips. WF9F/S. NIB. $150.
Scientific Anglers Mastery Series. Spey Shorthead Multi Tip. 4 interchangeable tips. WF10F/S. NIB. $150.
Scientific Anglers Mastery Series SLS WF7S III. This line is new on the spool. Unfortunately, the line very dirty/dusty from storage. This would benefit from being wiped down. $40.
Scientific Anglers Mastery Series. Stillwater Taper. WF3S. NIB. $45.
Scientific Anglers Saltwater. WF10F. I think this may be a Frequency line. The line is in great shape. No loop on head. Tag end loop is there, but worn. It may be best to cut it off. The line has been marked with a black sharpie near the head and again on the fly line further in. $40.
Scientific Anglers Sonar Sinking 25 Cold. WF-150-S. New in box. Retails for $100. $80.
Scientific Anglers Sonar Sink Tip 4. WF6FS. The line was spooled on a reel, but I don’t think it has ever been fished. Factory loops on both ends. $75.
Scientific Anglers Sonar Titan Intermediate. WF6F/I. New in box. Retails for $100. $80.
Scientific Anglers Sonar Titan Full Intermediate. WF6I. New in box. Retails for $100. $80.
Scientific Anglers Sonar Titan Full Intermediate. WF7I. New in box. Retails for $100. $80.
Scientific Anglers Tarpon. WF11F. Line has been used 3-4 times. There are factory loops on each end. They do have some signs of use from hooking some big fish. $70.
Scientific Anglers Ultra 2 WF8F/S Steelhead IV. The line has been used, but is in good shape. No loops. $25.
Scientific Anglers Ultra 4. DT7F Buckskin. NIB. $45.
Scientific Anglers Sonar Sink 25 Cold. WF300F/S. New in box. Retails for $100. $80.
Scientific Anglers Sonar Titan Full Sink. WF8S. S3/S5/S7. New in box. Retails for $100. $80.
Scientific Anglers Sonar Titan Sink Tip. WF7F/I. New in box. Retails for $100. $80.
Scientific Anglers Sonar Titan Sink Tip. WF8F/I. New in box. Retails for $100. $80.
Scientific Anglers Sonar Titan Sink Tip. WF8F/S. New in box. Retails for $100. $80.
Scientific Anglers Spey Lite Scandi. 240gr. Never fished. $50.
Scientific Anglers Tip. 8ft 80gr Floating. Excellent shape. $25.
Scientific Anglers Tip. 8ft 80gr S1S2. Excellent shape. $25.
Scientific Anglers Tip. 8ft 80gr S2S4. Excellent shape. $25.
Scientific Anglers Tip. 8ft 80gr S3S5. Excellent shape. $25.
Scientific Anglers Tip. 8ft 80gr S7. Excellent shape. $25.
Teeny TS650. This line was spooled on a reel, but never fished. No loops on either end. Comes with box and spool. $40.
Wulff Bermuda Triangle Taper (2-tone). WF6F. Used a few times. In great shape. Spooled on a mismatched spool from a Rio line. No loop on tag end. $50.
Wulff Bermuda Triangle Taper Shorts. WF10F. Used twice and in excellent shape. No loop on head. Home made loop on tag end. $60.
