Posted this on a request in Pathfinder section of MGB, thought it could be useful here…if anyone has specific wiring for various skiffs, might be a good resources for others.
Here is what my buddy GROK4 came back with…
I’m sure CHAT GPT will provide something similar…
Standard Wiring Color Codes for Boat DC Systems (ABYC Standards)
Pathfinder Bay Boats, like most marine manufacturers, adheres to the American Boat and Yacht Council (ABYC) E-11 standards for low-voltage DC wiring. These color codes ensure safety, consistency, and ease of troubleshooting across boat electrical systems. While specific models may have minor variations (e.g., custom harnesses),
the core colors are standardized. Always consult your boat’s owner manual or wiring diagram for model-specific details, as custom installations can differ.
Below is a comprehensive table of the primary ABYC-recommended color codes for boat wiring. Colors are for insulated conductors; striped wires (e.g., red/yellow) indicate secondary functions.
| Color | Primary Function | Common Applications | Notes |
| Red | DC Positive (main battery feed) | Battery switch, main bus bars, DC distribution | Unfused positive runs; use with circuit protection. |
| Black | DC Negative (ground return) | Battery negative, engine blocks, ground bus | Often bare or tinned for corrosion resistance. |
| Yellow | Starting circuit positive | Starter solenoid, ignition switch | Isolated from main DC positive to prevent shorts. |
| Purple | Ignition and instrumentation | Ignition switch, tachometer, senders (temp, fuel) | For engine controls and gauges. |
| Dark Green | DC Ground (chassis/engine) | Engine block, hull bonding, accessories | Use for grounding to chassis; not for main battery negative. |
| Light Green | DC Ground (alternating uses) | Spare or auxiliary grounds | Less common; often striped for specifics. |
| Brown | Generator alternator | Alternator output, generator circuits | For charging systems. |
| Orange | Common positive bus | Accessory circuits, 12V outlets | Shared positive for non-critical loads. |
| Dark Blue | Cabin lights | Overhead lighting, courtesy lights | Interior illumination circuits. |
| Light Blue | Signal circuits | Horn, bilge alarms, navigation lights | Low-amperage signaling. |
| Gray | Navigation lights (bow/stern) | Running lights, anchor light | Exterior navigation. |
| White | Unassigned/spare | Custom or future use; often navigation aids | Neutral in AC, but DC spare in boats. |
| Pink | Fuel pump | Fuel transfer pumps | Engine-related. |
| Tan | DC Auxiliary heater | Heater controls (if equipped) | Rare in bay boats. |
| Green | Bonding system | Hull bonding, underwater metals | Corrosion protection; green with yellow stripe for AC ground. |
Key Guidelines:
- Striped Wires: A base color with a stripe indicates a branch circuit (e.g., red/yellow for starter ignition).
- AC Wiring (if applicable): Follows different codes—black/hot, white/neutral, green/ground—but Pathfinder bay boats primarily use DC.
- Safety: All wires must be marine-grade (tinned copper, UL 1426). Use fuses/breakers at the source. For Pathfinder models (e.g., 2200 TRS or 2400 TRS), download the official wiring schematic from pathfinderboats.com under “Owner Resources.”
- Variations: Some Pathfinder harnesses use proprietary plugs, but colors align with ABYC. If rewiring, match to the factory loom.
If you provide a specific model or a wiring diagram PDF, I can help analyze it further!
