A few Fly Tweaks/ Questions
Been slow to get back into FL fishing following my trip to AK… but finally got the itch.
Been tying up some really small shrimp on size 4 hooks. Playing w the recipe a bit.
First- crazy how much hook sizes vary- even with same manufacturer.
The Gama C14S is really small(bought them in Alaska for trout on egg patterns).
They are dramatically smaller than Gama SL12S.
The Owner Mosquito is small as well- but offset.
Questions:
  1. I have only used non- offset hooks for fly tying. Am I foolish?!? Do offset offer an advantage I don’t know about? (I think straight is better when using a weed guard- but that is a guess).
  2. I created one shrimp with a “jig bomb” bead instead of bead chain. Anyone else try this?
  3. The jig bomb made an already “tippy” pattern even more so when hitting the bottom… so I added a small piece of mono to act like an outrigger to hold it hook point up. Anyone tried this?
The outrigger sits amongst the silly legs and looks normal.
My thought is to put this on a backup rod for any sheepshead I find on the flats on the next flood tide. Yes, my insanity at thinking I may actually catch one, continues.
I exclusively use those types of beads instead of eyes on my redfish flies. I have not noticed the tippiness but i dont really have the fly on the bottom much. I like the bead cause it helps the fly land softer imo and I normally trying to hit the fish in the face with the fly and get the eat on the drop after it lands or a few strips. I generally have the bead where the eyes would normally go though, not the rear.
I don’t use mono like that but a main pattern I use has a piece of EP fiber extending over the hook shank that probably is doing what you’re describing.
And yea the glo bug hooks are crazy small - i have caught reds on the #2 size with no problem though
Great feedback.
For a lot of my fishing- we need the fly in the bottom and sitting point up so it doesn’t foul in the grass (flood tide fishing in NEFL).
I used light mono so the line isn’t snagging grass too much, but it probably still will to a degree…. but without the outrigger, it was rolling over which would snag grass way too much.
I think the SL12S is too much for bonefish shrimp, but it’s a great hook for mini EP minnows!
@Loogie aren’t those SC15s?
@JaredD why do you need those heavy wire hooks?
Good eye, I tie lighter models with that SC15 hook, but I also use the SL12S pictured below.
Great question.
My hope is to get a sheepshead on one. They are tough on hooks, so need a small yet beefy hook.
I hope those glo hooks fit the bill.
Big fan of the tungsten beads on my crustacean flies.
you’ll probably wind up finding you need to cover that bead with a bit of dubbing or a brush to keep it from landing too hard. We use the wooly critter brush a lot. Even just a couple turns will dramatically lessen the impact of the fly on the water.
I have tried a lot of sparse ties like that and they mostly spook fish in my area.
Thanks for the tip. I appreciate it.
So, what about off set hooks?
Who uses them?
Any reason I should tie up a few patterns on a few?
For shrimp, check out the Gama SL45 - they have size 4 and size 6. I like the 6 for smaller patterns.
I’ve never tied with offset hooks before that I can recall. But I’ve seen some baitfish patterns tied with them. Never felt like I needed them. Maybe it triggered flashbacks of my dad’s carolina worm rigs when I was a kid.
Ahrex
Jared, I have some offset hooks that I tie big Tarpon flies for, they work well. I want to use them up since I got a good deal on them. Haven’t noticed improved performance, those bastards spit that hook as much as the straight ones.
thanks @Loogie
I have a bunch of offsets I bought by accident, but primarily use them for spin fishing now.
Will tie a few flies and see how they work out.
You ever try a circle hook fly for tarpon?
I have heard whispers around that.
Sure haven’t tried it,I have thought about it though. I think a strip set would not work as well as a straight hook, but that’s just theory.
